Mk3highline 10 Posted September 24, 2014 Hi I have been searching and seems like the vr6 rado and mk3 golf have same/similar suspension set up? Well basically before mot next month I've had a little nose under car and the track rods and bushes could do with replacing( not found an invoice in service history either) There is no knocking steering bit off I have found some new wishbones with the r32 rear bushes fitted, what benifits is ther with such a set up? I already have 30mm eibach springs with standard bilstien shocks I don want the ride any harder so avoiding power flex type The rack seems ok but while the wisbones are off may as well change the rods and boots etc Rubber on the ball joints are starting to crack Also how is it possible to be able to adjust the camber on the front and rear? Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 24, 2014 Thing is you have the Bilstein/Eibach setup which is uprated from standard the standard bushes will wear quicker with this setup however the Powerflex are made to work on this kind of setup it won't be greatly "Harder" however your bushes will last longer. Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 24, 2014 There only the pro kit springs. I didn't think 30mm made that much of a difference My days of hard/stiff suspension on ultra low profile tyres are gone lol Quote Share this post Link to post Share on other sites
clumpy1 11 Posted September 24, 2014 Harder than you think especially when coupled with Bilstein's they are renowned for being "Hard" mate I've had mate's ditch them in favour of Koni's as they were too Hard (on various car's) Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 24, 2014 Oh right they have been on the car since around 2007 Thank you anyways I need to change the wishbones either way as it seems there the OEM from factory How about the wheel alignment any perticular way to better the standard set up? Besides the anti roll bar Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 25, 2014 How is the 1.2 negative camber achieved on the corrado?? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 25, 2014 Adjustable lower ball joints and slightly loose fitting strut bolts. I'd go with the R32 wishbone bushes. They are basically solid rubber and not voided like the Corrado ones. VW seem to save those kind of bushes for their flagship cars and they do make a big difference, especially under hard braking and acceleration. Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 25, 2014 Cool thank you cant wait to get it all done Should see improved MPG not having to slow down for bends lol Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 25, 2014 http://m.ebay.co.uk/itm/191067021733?nav=SEARCH Found them Is there any partiular brands to avoid like qh or first line?? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 25, 2014 Never heard of them! Most people just get OEM R32 bushes pressed into their original wishbones. Pattern rubber and steel parts are always of dubious quality in my experience. Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted September 25, 2014 Well after some more serching it seems to be possible to use the mk4 r32 complete wishbones Will have a problem with the ARB links and it will widen the track slightly Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 18, 2014 Having this done finally(didn't get chance whilst doing engine) One other forum folk Said to have some TOE OUT I've always thought for better turn in to have wheels toe IN 1/2 neg camber ok? Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted May 2, 2015 I've just done both front ball joints after having them sat in the boot for 7 months!! With the camber set to -1.7 the difference is phenomenal Had a nose at the wish bones and they still seem ok we didn't have time or a press to do the other bushes Spirit level app depending how accurate on a level surface to get the camber before it was at -1.5 and front tyres have worn near enough even just need a proper alignment chech now and have a play with toe Quote Share this post Link to post Share on other sites
