georgia1990
ABS MOT fail
so having issues getting a ticket on my car due to ABS light not coming on and going out with ignition. however, the fuse went for the ABS pump a while back and abs light stayed on solidly ( so i know it works when theres a fault present, just doesnt seem to do prelim checks). has anyone come up against this problem before as i got limited free time to get to the bottom of it. and yes the ABS does work i tested it on a wet road. if anyone could help, would be greatly appreciated.:thumbleft:
I have Giorgia. Turned out to be the fusebox to light loom, and the light itself was broken too. The pins on the light unit were loose where the solder had broken down on the pcb.
