Hairyarse 10 Posted February 12, 2015 The sensor on the front of the engine block by the filter housing and oil cooler seems to be weeping oil. I've nipped the securing bolt up although it wasn't really loose which may have stopped it. However, I wanted to check parts base to see if there's an O-ring or similar to seal it but can't find it on there. Here's a pic of it; Also, looks like there's leaks from the cooler. Does this remove with the filter housing and can you get a refurb kit or similar for it? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 12, 2015 Crank sensor I think. Both mine leaked and they seem to chuck out loads of oil. They have a plastic sleeve on them which looks like a seal. But when I ordered it. It came as a rubber o ring. Quite a thin one. I've used a bit of sealant on the flat face of it as well. Fed up with leaks so used sealant on quite a lot of my new engine build. Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 12, 2015 Yeah crank seal. Just be careful if you remove it as the plastic is very brittle and they are known to brake at the bend. If it comes off in one piece the O seal should sort it. Oil cooler is separate from the filter housing. There are 2 seals for this, an inner and an outer where the securing plate goes on. Cheap enough and sold in quite a few different places. The filter housing seal I've only found available from VW or TPS though. Again, not silly expensive iirc. Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted February 13, 2015 Thanks for the feeback chaps ;) If I remove the sensor will I lose a lot of oil or is it just a weep? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted February 17, 2015 Oil won't pour out, it's too high up. The oil isn't at full pumped pressure there in the crankcase. Best wishes RB Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted February 18, 2015 Thanks Roger. My logic was telling me that but thought it's worth double checking ;) Quote Share this post Link to post Share on other sites
