Reverend Frog 10 Posted February 15, 2015 (edited) I need the red/pink plastic nozzle - part number 535955985 (thank to Leon below for that information) The (terrible quality) image below is of the washer motor assembly inside the bootlid. The loose nozzle is circled in red and the broken remains of the part I need are circled in yellow. I've attached a image of a healthy motor for comparison underneath it. Cheers. Rick [ATTACH=CONFIG]80908[/ATTACH] [ATTACH=CONFIG]80909[/ATTACH] Edited February 16, 2015 by Reverend Frog Quote Share this post Link to post Share on other sites
leon263 0 Posted February 15, 2015 (edited) The part which you are looking for is shown in the photo below which is of the similar item which is used in a Mk3 Golf. The Corrado one is pink in colour and the long tube part is 31mm longer. The Mk3 part which is still available will NOT do the job as it is too short and unfortunately the Corrado part is obsolete. The actual nozzle, which is the top part shown in the photo, is still available from Classic Parts so it might be worth your while giving VW Heritage a ring and asking about the tube. Failing that, your only chance is to get the original part from a breaker or from some-one who has removed the rear wiper. It is simply a push fit into the red plastic part on the base of the motor and runs up through the centre of the wiper motor spindle. The nozzle is a push fit into the tube from the top. Tube and nozzle part number for the Corrado is 535955985 Edited February 15, 2015 by leon263 Quote Share this post Link to post Share on other sites
