Chargemeup 10 Posted February 17, 2015 Hi all, had my G60 on the road for a month now after servicing the charger and doin numerous other bits. But the past couple of weeks the throttle has been sticking, anywhere between 1500 and 5000 rpm! This only happens when it's cold, as soon as its warmed up its fine, but it's very annoying! I've checked the cable, that's good. I've removed the ISV and that's free. What is the next thing I should check? the only mod I've got is a 68mm pulley and chip from Ocd, but I'm pretty sure it's not this as it was fine for a couple of weeks. Any pointers would be much appreciated. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted February 18, 2015 Don't know if this will shed any light on the problem. http://the-corrado.net/showthread.php?t=32650 Quote Share this post Link to post Share on other sites
Chargemeup 10 Posted February 18, 2015 Thanks Ray1965. I will defo try this. I had another fiddle last night and found the throttle cable was a little sluggish returning. I disconnected it and the throttle body spring back no problem. Does anyone know where you can get a throttle cable from if I need one or can you service them? The thing I don't get is it's fine when the engines warm??? Quote Share this post Link to post Share on other sites
Ray1965 10 Posted February 19, 2015 No worries, The cable does sound as if it is in need of some lubrication. As for the problem it's self i don't think it is cable related. You could try contacting VW Heritage for a new cable. https://www.vwheritage.com Quote Share this post Link to post Share on other sites
