Johnboy98 0 Posted June 16, 2004 Hi all Just ordered this from the states in place of a shrick controller anyone got doubts as to why it would'nt work ? http:// [url=http://store.summitracing.com/partdetail.asp?part=SUM%2D830449&view=257#largerimage]http://store.summitracing.com/partdetai ... argerimage Vendor: Summit Racing Equipment Product Line: Summit RPM Activated Switch Finish: Black No more lost modules. RPM activated switch Our RPM activated switch uses internal DIP switches to select the rpm setting instead of expensive pills or modules which can get lost or vibrate loose. Our switch also has an adjusting knob inside the unit that lets you fine-tune to any rpm from 2,000 to 9,800 rpm. A green LED light lets you know when the desired rpm is reached--no need to turn on a connected device to see if the switch is working. We also include a red LED power indicator, an internal fuse, and extensive input protection circuitry to keep the switch from blowing up if you connect it to something that draws too much current. Sold individually. $45.95 Should Ship By: Today Quote Share this post Link to post Share on other sites
VR6 0 Posted June 16, 2004 Good luck with the search and everything, but do we have to have 3 threads a week about it?! Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 16, 2004 Good luck with the search and everything, but do we have to have 3 threads a week about it?! Only if you really want to be pedantic, this would and will be usefull to all if they ever want to replace there exsisting controller for a fraction of the price!! I thought that sharing info and gleening it was the true ethos of what these forums are all about!! So back off War Child!! Quote Share this post Link to post Share on other sites
VR6 0 Posted June 16, 2004 Good luck with the search and everything, but do we have to have 3 threads a week about it?! Only if you really want to be pedantic, this would and will be usefull to all if they ever want to replace there exsisting controller for a fraction of the price!! I thought that sharing info and gleening it was the true ethos of what these forums are all about!! So back off War Child!! lol - war child :lol: It's just that I seem to have seen about 3 or more separate threads about your search for missing shrek components. I'm just in a bad mood, so take no notice of me Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted June 16, 2004 That's a brilliant find and for a fraction of the price of a genuine schrick contoller! Just hope it works ok. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 16, 2004 Yeah that is a good find! Mega cheap too! Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted June 16, 2004 Would the plug which connects into the solenoid be available from vw? Think you might be able to buy a plug with the wires attached to solder on to. Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 16, 2004 Dunno but ill keep you all posted as too my progress..... :wink: Quote Share this post Link to post Share on other sites
VR6 0 Posted June 16, 2004 In this thread hopefully ;) :lol: Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 16, 2004 In this thread hopefully ;) :lol: Depends what kinda mood " I am in" ! :twisted: Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted June 17, 2004 the valve/switch thing is just an air con component, so yes, you can buy the vw connector for it. I'll update the schrick faq theread with the part numbers soon. Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 17, 2004 Could any of you peeps email me or post a copy of the original instructions that came with yeh Shrick manifolds ? :roll: Arh go on .....Please !!!!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 17, 2004 On the electrical side:- Controller red wire to ECU pin 23 - (thick blue/red wire) Controller blue wire to ECU pin 22 - (thin black/green wire) Controller black wire to earth On the vacuum side:- Large vac pot input to servo hose accessory outlet Small vac pot input to bottom solenoid input Top solenoid output to flap actuator HTH K Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted June 17, 2004 Johnboy98, I'll send you the instructions if you want? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 17, 2004 I'd like to have a copy of the instructions too, if poss. Electronically is perfect - yahoo just bumped my quota to "lots" of MB :) Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 17, 2004 Johnboy98, I'll send you the instructions if you want? Thanks bud, the email addy is mailto:[email protected] :wink: Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted June 18, 2004 DrMat, you have pm! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 18, 2004 Merci buckets. ;) Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted June 18, 2004 Thanks dude , really usefull I owe you 1!!;) Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted June 18, 2004 no problem :wink: Quote Share this post Link to post Share on other sites
