3xxx3 10 Posted March 5, 2015 (edited) Now is the time that I would have taken the engine out of my g60, to make a small servicing on it. when I will have changed the oil pump Car engine has run 200.000 km setup now. 68 mm pulley Rally intercooler not monterte but purchased max ported intake manifold Corrado G60 TeZet exhaust header stainless BBM 8V Fuel Rail, Digifant I & II 3.5 Bar Fuel Pressure Regulator It's supposed to block and top must stay together the whole will be shifted from the bottom. Shopping list is as follows Klüber coating fat for G40 and G60 Supercharger / G-Lader 9,00 EUR 9,00 EUR Delete Loctite 638 joint-shaft-hub 10 ml 15.90 EUR 15.90 EUR Delete Brake cleaner spray can 600 ml 1.99 EUR 1.99 EUR Delete Oil supply line G-Lader 42.90 EUR 42.90 EUR Delete Overhaul G60 - large 319.00 EUR 319.00 EUR Delete Slinger for G40 and G60 Supercharger / G-Lader 29.90 EUR 29.90 EUR Delete Kühlwasserflansch / socket G60 13.90 EUR 13.90 EUR Delete Cooling water pipe / flange G60 - cylinder head side 9,90 EUR 9,90 EUR Delete Engine bearing front - Hydro G60 71.00 EUR 71.00 EUR Delete Asymmetrical camshaft 268/276 ° - Schrick 295.00 EUR 295.00 EUR Delete Oil Filter G60 13.80 EUR 13.80 EUR Delete Oil pump G60 154.00 EUR 154.00 EUR Delete Connecting rod - Kit ARP G60 139.90 EUR 139.90 EUR Delete Temperature sender G60 blue 20.49 EUR 20.49 EUR Delete Thrust washers / spacers crankshaft VW Golf G60, Corrado, Passat 14.90 EUR 14.90 EUR Delete Crankshaft bearings / main bearing shells racing VW G60 with 360 ° oil groove 84.90 EUR 84.90 EUR Delete Main bearing studs ARP G60 168.90 EUR 168.90 EUR Delete Injectors G60 Golf 299.00 EUR 299.00 EUR Delete Connecting rod bearing RS2 / sputtering for 1.8 and 2.0 16V engines KR PL ABF 99.00 EUR 99.00 EUR Delete Intake manifold gasket G60 - large version 17.49 EUR 17.49 EUR Delete Gasket set engine block VW Golf G60, Corrado and Passat - Motordichtsatz 109.90 EUR 109.90 EUR Delete Crankshaft sprocket bolt + G60 / PG motor 38.90 EUR 38.90 EUR Delete Timing belt and tensioner roller G60 49,90 EUR 49,90 EUR Delete Intermediate shaft bearing / balance shaft for VW 1.0 - 2.0 ltr. 8V and 16V motors 21.90 EUR 21.90 EUR Delete Hydraulic lifters Schrick G60 and all 1.3 to 1.6 1.8 2.0 L 8V hydraulic motors 139.00 EUR 139.00 EUR Delete incl. 19% VAT. 348.14 EUR Subtotal: 2,180.47 EUR plus shipping and handling Question 1 Is it overkill to switch to the Connecting rod bearing RS2. and it is ok without grinding the crankshaft Question 2 Is it overkill to switch to Crankshaft bearings / main bearing shells racing VW G60 and it is ok without grinding the crankshaft Question 3 When need to replace the bearings would you then switch to ARP bolts Question 4 Injectors G60 The flow rate (315 cc to 3 bar) is Identical til gray G60 nozzles of Bosch no. 0280150923 or 0280150924 or VW number 037906031 E / F Will not they work fine with a new chip Question 5 Chip is the plan to get one from SNS chip Anyone have anything to add. Any advice, or just concerned Google translate, since I am dyslexic Edited March 5, 2015 by 3xxx3 Quote Share this post Link to post Share on other sites
