akacheesy
Interior Light
Which version of the interior light?
Oh, and double post removed....
Probably 1993 on. Is the sunroof switch a rocker switch with a button in the middle,or a weird shaped lever?
Either way, plastic wedges on the drivers side and a springy metal tab on the passenger side.
Depending on how loose it is at the moment, either get your fingernails under the edge of the passenger side edge and pull, or get you fingernails under the driver's side and push the whole unit towards the passenger side untill the plastic wedges dis-engage and the whole lot drops out.
Neither approach is what you'd call comfortable, but it doesn't do any damage to the car.... :wink:
