16VG60
Late ABS Warning Light Unit URGENTLY Required
I urgently require a late in dash ABS warning light to get a Corrado through MOT. The part number of the unit is 535 919 235 BA. There are a number of variations used in the Corrado over time so could you please check you have the correct item before raising hopes :). The light unit i need has a single 7 pin flat plug supplying it. Please call me on my mobile if you can help 07974020031. I look forward to hearing from you.
Regards, John JMR Ltd
