Diesel2000
Random Fast Idle
My 16v 2.0 has randomly started idling at about 2000rpm. Its fine when I start it but after driving for a few seconds the idle seems to stick.
Any ideas?
After fitting a 50mm intake to my valver it started doing weird/intermittent idle hunting (not sticking) but only seemed to be when it got warm.
Turned out to be the elbow on top of the metering head - no obvious damage or splits, but when pressed against it stopped the hunting.
Check for vacuum leaks as it will cause idle issues. Also clean the ISV while your at it.
