glen.owen.140 10 Posted May 3, 2015 I have replaced master and slave and line and that works great how ever peddel will not return all the way how can I check the cluch fork with out removing gearbox ??? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 3, 2015 Hi, did you pressure bleed it? What slave did you use, some of the cheap ones are awful, maybe faulty Quote Share this post Link to post Share on other sites
glen.owen.140 10 Posted May 3, 2015 It was a cheap one I bleed it from the bottom up the line then clamped the slave and peddel was hard with no movement but bolting slave back in gearbox peddel dropped about 3 inch and I can hear the clutch trying to disengage but not enough to engage any gears has any one measure the distance between the fork and the hole in the box Quote Share this post Link to post Share on other sites
