VR6 Lee 0 Posted May 6, 2015 How hard is it to replace the handbrake cable on the Corrado? 2 hour job? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 6, 2015 Theres 2 remember bro Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted May 6, 2015 Yep! I need mine doing! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 6, 2015 Depends if the metal sleeves are rusty / siezed - try and buy these too as it might make things much easier! Quote Share this post Link to post Share on other sites
ChrisL 18 Posted May 6, 2015 Took longer to get the centre tunnel and handbrake handle off. Not a bad job though. Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted May 6, 2015 Will have to get some prices for cable.. knowing my luck bet they cost £100 or they don't supply them anymore...lol! Quote Share this post Link to post Share on other sites
ChrisL 18 Posted May 6, 2015 I just changed mine, they were just under £20 each and the guild tubes came to about £15 for the pair. I only changed mine because the part numbers on the cables weren't as bright a white as new ones! Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted May 6, 2015 I just changed mine, they were just under £20 each and the guild tubes came to about £15 for the pair. I only changed mine because the part numbers on the cables weren't as bright a white as new ones! From VW? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 6, 2015 Cheaper if you go for paigid cables fro eurocarparts about 12 quid each. Work out if you can get the handbrake handle grip off first..... :) Quote Share this post Link to post Share on other sites
ChrisL 18 Posted May 6, 2015 Yep! Both the cables and guide tubes from vw Quote Share this post Link to post Share on other sites
ChrisL 18 Posted May 6, 2015 Cheaper if you go for paigid cables fro eurocarparts about 12 quid each. Work out if you can get the handbrake handle grip off first..... :) You won't get the vw part number on them though so you can carefully position them so you can see it!! Or Is that just me being OCD? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 6, 2015 Yeah good luck with the handle i had to saw mine off and replace with new Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted May 6, 2015 Yeah good luck with the handle i had to saw mine off and replace with new Thats because your a bandit Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted May 6, 2015 :snipersmile: I think I had to glue mine back on....lol!!!! Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 7, 2015 Handbrake cable part numbers from dealers 1H0 609 712E ECP 108440798 Steel Clips 1H0 609 734 D I found the hardest part of the job, getting the steel clips off. This will help. http://forums.vwvortex.com/showthread.php?3055220-DIY-Replacing-and-adjusting-e-brake-cables-on-a-MKIV-car Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted June 5, 2015 Handbrake cable part numbers from dealers 1H0 609 712E ECP 108440798 Steel Clips 1H0 609 734 D I found the hardest part of the job, getting the steel clips off. This will help. http://forums.vwvortex.com/showthread.php?3055220-DIY-Replacing-and-adjusting-e-brake-cables-on-a-MKIV-car How much we're all the parts Quote Share this post Link to post Share on other sites
