dub_howells93
1.8 16v kr !!!!HELP!!!!!!
hi guys new here just got myself a 1.8 16v corrado on a J plate. it is a project as i only paid £400 :D bargin....
today i found that the crank case breather was leaking oil into the air filter so toke it all apart and give it a good clean with carb cleaner left all the top of the air box connected just cleaned it underneath... now the car wont start :(
some one please help me
thanks
Vac hose has probably come off. On the main inlet pipe from the metering head to the throttle body, there should be a pipe pushes in underneath it. It normally pulls out when you change the air filter. Check that - or all other vacuum pipes are properly home. (I'm assuming the engine is turning but not firing?)
Bargain Corrado by the way!
...hope that makes sense? lol
I'm assuming it will be identical to KR 16v in MK2 Golf. (I had this problem.) I can't find a picture of it, but in this link the pipe I'm referring about is hiding under part number 38 on the diagram - http://www.partsbase.org/vw/golf-go-eu-1992-1g-n-300-000-5350-air-flow-meter-fuel-metering-valve-intake-connection-air-filter-with-connecting-parts/
