dickie
Abs system delete
The corrado I'm building at the moment had the abs system, I want to get rid of this as I'll be running aftermarket brakes.
Can the original master cylinder be used or do I need to find a non abs one maybe from a mk2 gif etc?
Thanks rich
To me that statement says, I'm currently using size 9 feet but I want to cut them off at the ankles because I want to wear size 10 shoes.
Why ditch the abs?
Some people prefer no abs, especially if on a track car. I don't believe you need to change the master cylinder but make sure it has a load valve fitted at the rear. I can't remember but i'm sure later abs systems done away with the load valve.
