Finch 10 Posted July 26, 2015 Having an issue with my clutch sticking down only seems to stick down when crawling in 1st gear but if I pull it back up its fine doesn't stick any other time don't slip or have any other issues any ideas Quote Share this post Link to post Share on other sites
Dox 22 Posted July 26, 2015 Mines doing similar when first started from cold, someone said pedal return spring 22 - 23 - 24 in the diagram I presume? http://www.partsbase.org/vw/corrado-cor-eu-1994-126-brake-and-clutch-pedals-cluster/ Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted July 27, 2015 possible slave or master cylinder at fault, you can disconnect the clutch Master cylinder at the pedal with a flat screwdriver by removing the clip to see how free the pedal itself actually moves, i just replaced my M/C for the same reason, pics in my thread,members gallery last page if interested Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 27, 2015 May just need bleeding - when was the brake fluid last changed and did they do the clutch? Quote Share this post Link to post Share on other sites
Finch 10 Posted July 28, 2015 Going to check the return spring first if it's not then going to try the fluid but reading vw_owner_85 thread think it's same problem so looks like master cylinder :( but will keep you posted thanks for the help guys Quote Share this post Link to post Share on other sites
Finch 10 Posted August 6, 2015 Turns out it was the master cylinder thanks A lot for your help guys Quote Share this post Link to post Share on other sites
