daves16v
Corrado VR6 Black 1994 - SOLD
Well the time has come to part with my Corrado and move onto other things.
I've owned the car since 27/03/2010 and have carried out extensive work during that time, all receipts have mileage and dates, below is the full spec. Most of the work carried out is detailed in my members gallery here -
http://the-corrado.net/showthread.php?48656-Black-Metallic-VR-Inlet-Temp-Sensor-Upgrade
There is a huge pile of receipts from my ownership and more from previous owners.
The car is always kept in a heated garage.
1994M Corrado VR6
Brilliant Black Metallic LA9V
First registered 08/08/94
180710 miles on the car
130k miles on replacement engine (fitted at 179035 miles on 08/04/14)
MOT expires - 19/07/16
BBS RC alloys 7.5x16" with polished centre caps and locking wheel bolts
Bastuck 2.5? exhaust with round tailpipe complete with Stainless Steel rear box hanger
Cobra Full Closure Alarm
Glass Sunroof
Black Heated Leather Interior with Stainless Tilt Handles
OBD2 Conversion
Smoked Rear Lights
New Parts During My Ownership:
Schimmel 263 Cams
INA Tappets
Replacement Timing Chains and Tensioners
VAG complete clutch, bearing and lever arm
Clutch Master and Slave Cylinders
VAG thermostat and housing/seals
Bilstein B12 Suspension Kit
VAG Front Top Mounts and Bearings
Golf 02J Shifter
Stainless Gear Surround
NGK spark plugs
Sump fitted with baffles and powder coated
Sump Gasket
Injectors Refurbed
ARB Links
Serpentine Belt
All coolant senders
Radiator sender
Coolant Radiator
Coolant
Fan mounting powdercoated with Stainless fixings
Front Suspension Ball Joints
Replacement washer piping
VDO oil pressure sender
VDO Gauges
Fuel Filter
Water Pump
Ignition Switch
Golf Mk4 Header Tank
Golf R32 Rear Wishbone mounts
Wishbones Powdercoated
Rear suspension beam powdercoated and fitted with new axle bushes
Rear discs, pads and wheel bearings
VAG Coilpack
Goodridge rear braided hoses
288mm front calipers recently refurbed with new seals and powdercoated
Front Stainless braided hoses
Golf Mk4 rear calipers
Lupo Aero Wipers
Battery
Oil Temp Gauge Sender
VAG floor mats
VAG Crackpipe
VAG Aux water pump
Front and rear seat guides
VAG oil cooler seals
VAG door pins
Beru spark plug leads
Smoked side repeaters
Stainless tailgate strut screws
Tinted headlight reflectors
Centre tunnel fixing bracket
Uprated door handle striker arms
Rear wiper removed
Rear towing eye removed
Golf Mk4 Leather handbrake
The Engine Bay has undergone extensive custom modifications as detailed below -
All plastic engine covers removed
SWG Single Piece Scuttle Panel
Part powdercoated and polished cam cover
Powdercoated inlet manifold
Polished throttle body
Custom designed Polished Stainless Steel HT lead holders
Polished belt tensioner
Polished Stainless Steel radiator elbow
Carbonio Induction Kit with Polished Stainless Steel mounting
Stainless Steel custom made header tank bracket
Stainless Steel custom made vac pipe bracket
Stainless Steel bonnet prop
Uprated headlight loom with Stainless relay enclosure
Various Stainless underbonnet screws
Stainless radiator brackets
Various Polished Stainless Hose Clamps
Trimsport Polished Alloy Oil Filler Cap
Bonnet insulation removed and polished
There are numerous other polished Stainless Steel brackets in the engine bay too many to mention. It really needs to be seen!
Bad Points:
Rear tyres are nearing their limit.
There is no Stereo but the engine makes up for that!
There has been some panel repaint done by a previous owner that doesn't quite match other panels.
Stonechipped bonnet
There are some parking dents but nothing major.
Some minor wear to the driver seat bolster but nothing major.
List Date: 8/23/2015
For more info, click here to view the original listing: Corrado VR6 Black 1994
SOLD
the-corrado-forum
Mobile friendly version: Corrado VR6 Black 1994
