SR_Neale 10 Posted September 1, 2015 Hi all. Have just been lucky enough to buy a leather interior for the rado. My question is what glue is best to use to re attach the leather where it has come away on the door cards. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted September 1, 2015 good question - I need to do similar to the door cards in the valver I was going to use some hi temp contact adhesive or similar if I can find any - hi temp due to the top of the door card being in the sun Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 1, 2015 Something like this http://www.as-trim.co.uk/index.php?main_page=product_info&cPath=1_18_31&products_id=71 They also do a thicker glue of the same type. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 1, 2015 i did mine recently and just used a normal superglue i had lying around Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted September 1, 2015 Cheers jim. I knew I had seen your pics with the pegs but just couldn't remember where. Did you have any issues with using normal super glue? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted September 1, 2015 I like the temporary 'securing' mechanism lol Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted September 1, 2015 I like the temporary 'securing' mechanism lol Knowing my luck I'll end up getting the pegs stuck lol. Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 1, 2015 I use this and it's excellent. http://www.as-trim.co.uk/index.php?main_page=index&cPath=1_16_20 The only thing to be wary of with superglue it does eventually go brittle and will start breaking up Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted September 1, 2015 I use this and it's excellent. http://www.as-trim.co.uk/index.php?main_page=index&cPath=1_16_20 The only thing to be wary of with superglue it does eventually go brittle and will start breaking up I think I'll give this a go. Wasn't over keen on using super glue due to the possibility of it bleeding through and ending up with white blobs everywhere. How far does it go as there isn't a huge amount to do? Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 1, 2015 I think I'll give this a go. Wasn't over keen on using super glue due to the possibility of it bleeding through and ending up with white blobs everywhere. How far does it go as there isn't a huge amount to do? It does go quite far. I reckon the smallest tin would be more than enough. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted September 1, 2015 Knowing my luck I'll end up getting the pegs stuck lol. ha ha ha make sure you don't use plastic pegs - old skool wood only ;) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 1, 2015 Retro-pegs ftw Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted September 1, 2015 It does go quite far. I reckon the smallest tin would be more than enough. thanks Jamie I will have a look into that also Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted September 1, 2015 Love a bit of wood lol Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted September 1, 2015 I had great success with TrimFix High Temp spray adhesive. Just mask up everywhere and take your time. I used pegs, too... Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted September 1, 2015 i did mine recently and just used a normal superglue i had lying around This sends shivers down my spine as used the same method very good but time consuming Quote Share this post Link to post Share on other sites
Jamie 1 Posted September 1, 2015 I didn't have to use any form of clamp - once that AS glue grabs it's stuck. The downside obviously is you need to get it right first time Quote Share this post Link to post Share on other sites
fonzooorooo 10 Posted September 1, 2015 If you need more pressure from the retro pegs, wrapping rubber bands round them works well. Quote Share this post Link to post Share on other sites
Storm Guy 0 Posted September 1, 2015 lol...Brings back memories. Evo serious glue, but just needed to do some edges. [ATTACH=CONFIG]82285[/ATTACH] [ATTACH=CONFIG]82286[/ATTACH] Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted September 1, 2015 lol...Brings back memories. Evo serious glue, but just needed to do some edges. [ATTACH=CONFIG]82285[/ATTACH] [ATTACH=CONFIG]82286[/ATTACH] Tut tut you didn't use old school wood. Quote Share this post Link to post Share on other sites
