bigpants baby
3.2 vr6?
just bought a passat with a 2.8 vr engine,if i wanted to have this motor bored out what is the biggest size i can have it bored out to & how much for the piston etc set up?
Have a word with Chris, aka CorraodVR6NOS. He knows all about this. You can go much larger than 3.2 with the right crank, rod and piston combination apparently. I don't know the exact details I'm afraid.
A 3.1 build using 11:1 CR JE pistons with Schrick VGI, 268 cams and remap will yield somewhere in the 240 to 250 region with the torque to match. That's a conservative figure, you may get a little more if Geoff Everett applies his magic to the remap.
It costs a lot of money to achieve that though, but it's a solid, good performing motor.
K
Well over 300....but you'll have to use the JE 9:1 pistons and Raceware rod and head bolts to hold the engine together when on boost.
Cheaper to build a 2.8/2.9 turbo.... and get more power/torque
