shottylad
VW Corrado G60 stage 2 FSH Bordeaux Pearl
1992 Corrado G60 in bordeaux pearl
Mileage is just over 102,000 (very low mileage for year) and has full service history.
The car has been meticulously maintained, not being modest but it's one of the tidiest Corrados I've seen around.
It has MOT until February 22nd 2016 and I have box file that is stuffed full of receipts, it has had no expense spared and anything the cars has needed it has had! The previous owner told me it has over ?9000 worth of receipts, and now there will be even more.
It has recently had an oil change, and also previously had new water pump, belts, tensioner bearings, and handbrake cable.
Engine spec
1.8l G60
G werks rebuilt supercharger which has been ported and polished at 70,368 miles with certificate of proof.
68mm charger pulley
Braided oil feed pipe to charger which is a must for all G60's
Sns stage 2 remap
Mocal remote oil cooler
Shrick spilt profile camshaft with new followers (better power curve)
BBM RSR outlet kit for charger
VibraTechnics Engine mounts
Full stainless miltek exhaust system with a G werks stainless Decat Pipe (Standard cat incl)
New Bosch lambda sensor
Samco Vacuum hose throughout engine bay to ECU etc
Uprated crank pulley bolt
Engine runs absolutely amazing, no smoke or oil leaks, sounds crisp and pulls hard throughout rev range.
Suspension
60mm Weitec ultra gt lowering kit
Also new front suspension top mounts
Brakes
Standard G60 brakes fitted with EBC cross drilled discs and EBC Greenstuff pads
Interior
Cream leather storm interior with no rips or tears in very good condition
MOMO millenium steering wheel
Remote central locking
Power steering
Electric windows
Electric sunroof fully working (one of the few!)
(Also active rear spoiler fully working)
Bad bits- every car has a few unfortunately!!
Crack in O/S/F indicator lens
Heater fan only works on the 4th setting (I believe this is an easy fix by fitting a new thermo fuse on the fan assembly a matter of pence and a bit of work to fit- I never got round to doing this as it never bothered me.
I will be sad to see this go but although I have used this as my daily driver, I now need only one car in the household due to my partner now working from home. So this has to go as now is currently SORN'd and not being used.
I am after ?3250 o.n.o and I am in Newcastle-Under-Lyme near Stoke-On-Trent and can be contacted on Tel: 07894 456499
List Date: 9/30/2015
For more info, click here to view the original listing: VW Corrado G60 stage 2 FSH Bordeaux Pearl
On Sale For: ?3,250.00 (Local Pickup Only)
the-corrado-forum
Mobile friendly version: VW Corrado G60 stage 2 FSH Bordeaux Pearl
