Richard92
Abs pump fuse
Hi!
When i started the car to go home after work today, i noticed that i had no brake boost whatsoever, and suddenly the brake fluid was to high.
After some swearing i got the abs fuse out and it was gone, so i replaced it. Everything worked as a charm, so I drove home carefully.
Anyway, to the question; since the abs pump worked fine driving to work and the fuse probarly went poof when i shut down the car, is there anything i should check?
Like a list of things to go through for my own safety, before i write it off as an one time incident which caused a blown fuse?
Cheers
Richard
