BarberG60 10 Posted December 5, 2015 I know there were a couple on here before. I have a IHI turbo converted G60 but have a few questions about the setup. Fuelling,boost controllers etc Can anyone point me in the direction of someone who knows this setup? Jabbasport will be mapping the car in the new year, but I would like to get it running properly before then. Thanks Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted December 6, 2015 What do you want to know? Help me a bit too, what IHI turbo is fitted? Same goes for the other components, ecu type? Need mote info.. Quote Share this post Link to post Share on other sites
BarberG60 10 Posted December 6, 2015 It's an IHI VF turbo (24 I think) Running standard G60 management with a base map from Jabbasport for the turbo. Red top injectors, standard engine internals. Car runs very rich, bore washing to some extent. Can't work out why .Ecu vacuum hose is new and 11M long .No air leaks. Also, what boost controllers are people running? The turbo actuator is not adjustable, so must need an electronic one to up the boost as they car does not seem overly quick. Any people running a turbo could you give a description of your setups......with pics if possible? Thanks Quote Share this post Link to post Share on other sites
Slimg60 0 Posted July 7, 2016 I bought a complete IHI turbo'd engine from Junkie. It was running standalone management. Mine was a VF22 turbo on a big valve head, to say it was insane was an understatement!! Quote Share this post Link to post Share on other sites
