dythama
Water pump bolt needed - obsolete
Hi guys, I need a water pump bolt for my 16V, part number 051 260 821. I only need one as pictured on the left of the picture below.These longer bolts are used to secure the bottom of the water pump.
Does anyone have one they can spare?
[ATTACH=CONFIG]82811[/ATTACH]
Thanks in advance.
Hi
What dox said!
Or even an old bolt thats long enough and threaded all the way up cut the head off screw into hole then if its crucial for alignment of whatever goes on the end cut and or grind or file a nut down so its the same thickness as the existing bolt head tighten it down and the use another regular nut for whatever goes on the end
If alignment isnt important just use a regular unabused nut
Thats what id be doing if i was stuck with a car that didnt work just because of a bolt missing at least then you can still use it whist waiting to get the right bolt
Aki
