Fredi
Rough running 16v
Wish me luck, going to investigate some rough running issues. Engine is not holding a high enough idle so is dying at junctions...also erratic power delivery while accerlerating...
Guess I will start with the isv if I can find it....
Very green and new to corrado ownership..
Wish me luck..:scratch:
Check the dizzy cap. Mark it's location and take it off and spray with wd40 or similar spray. I used to valet cars and it happened quite a lot with me till I learnt to avoid that area.
Got nowhere so far really, had the dizzy off and cleaned it and the rotor...
Also located the isv, whipped it off and cleaned it out...no difference at all, still losing idle, revs just drop away..
Help....
