MAHN vr6 10 Posted December 31, 2015 Hi guys I just got the new springs for a custom coilovers set my mate is putting together for me, but once there fitted, the geometry will need setting up. We have a camber setter but what settings do you guys use for a fast road set up? Going to take it somewhere after for the toe in and out, anyone got any numbers that work well the a Corrado? Cheers Quote Share this post Link to post Share on other sites
jekel 10 Posted January 11, 2016 3.5 degrees camber on front handles like a go kart, but eats tyres, and scrubs a bit on straight, tremendous turn in on tight corners, 2 degrees a good compromise I think, got that and 1.75 on back, really depends on roads/corners your looking at, but good all round, got zero toe in/ toe out. 17's with 205 40's and Koni's (very stiff) Quote Share this post Link to post Share on other sites
MAHN vr6 10 Posted January 11, 2016 Cheers mate, that gives me a good idea, I'll probably start with 2 degrees on the front and 1.75 on the rear, see how it feels and keep the toe how you said Quote Share this post Link to post Share on other sites
jekel 10 Posted January 12, 2016 I've got strut braces front and rear which I'd recommend, and make sure you've got good drop links, Meyhles are good, cheap and easy parts to change, 30 minute job, I put big beefy washers either side of the rubber too, to restict the movement a little more, good upgrade, R32 rubbers on the suspension arms a must in my book, but are a pig to fit, probs easier to buy new arms with them already fitted Quote Share this post Link to post Share on other sites
