Marty63 10 Posted January 15, 2016 Hi guy,s I'm after some advice with regards to nology plugs has anyone had any dealing,s with them,basically are they any good or should I stick with good old Bosch,any advice would be appreciated thanks in advance. Martin Quote Share this post Link to post Share on other sites
jekel 10 Posted January 17, 2016 Never tried Nology but don't use Bosch, don't suit VR6's, there's a reason a German company used foreign plugs, use the original equipment NGK's. The platinum plugs and presume silver ones or just for longer service intervals no other advantagee and your a better with standard and change at regular imtervals, your not not going to not service your VR6 for 30 000 miles I'm sure. Some people actually prefer the single electrode NGK's which can buy for nothing as you can gap them, the twins are factory set. Quote Share this post Link to post Share on other sites
Jim 2 Posted January 18, 2016 Assuming we're talking the VR6 the 'factory' and recommended plug is the NGK BKR5EKU which are available from EuroCarParts for only about £4/each. There's no real need for any other type of plug unless you're running a heavily tuned application. Quote Share this post Link to post Share on other sites
Marty63 10 Posted January 19, 2016 Jim,Jekel, thanks for the replies I neglected to mention mines a G60 not VR6 I don't now if this will make difference to info required,butt thanks again guys much appreciated. Quote Share this post Link to post Share on other sites
