seanrodford
Power steering rack and pipes
hi sean
FYI having recently replaced the steering rack on my valver I should mention, if you are not aware, that the racks have a part split based on chassis number
they differ in the spline, one being coarse & the other being fine, & do not interchange
might be worth you stating what version spline this has to save any issues
I will check it out Friday when I go back over the unit :-)
good move
it caused a 10 day delay with my valver as I had to have the rack swapped out for the correct splined version
I might have G60 pipes if you can cross ref the part numbers online?
