John Blount
I've blown a oil pressure switch
Could someone help me confirm oil preasure switch part numbers for a VR6?
Had a major oil leak this morning from the left hand black switch so I need to replace it along with the right hand brown one.
The black switch I think says 068-919-081 ( 1.2-1.6 bar) is this the correct part number?
The brown switch I can't read but I believe this has been superseded to a blue switch, part number please??
Thank you??
Edited by John Blount
W068 919 081D black high pressure switch
W028 919 081H was brown and is now Blue low pressure switch
I was desperate so went to the dealers instead of Tps £13.75 each plus vat total £33.00
That was 3 weeks ago. Seemed a cheap fix for an oil leak so I can't complain.
I did need a deep socket to undo/tighten it. I think it was 17mm but a quick job and I was really pleased
