JEZR
Ally MAF - £60
This is the other part that works on my late VR6. There's a smaller connector for the Inlet Air Temperature sensor - normally this is screwed into the passenger side of the upper inlet manifold, but here it gets very hot due to engine temperature being conducted in through its metal case. Moving it lets the ECU measure inlet air temp more accurately, and as colder air is more dense it will add more fuel and slightly increase horsepower.
http://forums.fourtitude.com/showthr...n-VR6-manifold
Your stock IAT sensor has the same plug, so you can just unplug it and extend the two wires. Or leave it as it is and just use the MAF portion!
Have a look at the photos for condition.
£60 + £7 post or happy to combine with the elbow. [ATTACH=CONFIG]83147[/ATTACH]
Can send more images.
Edited by JEZR
