Rado87 10 Posted February 18, 2016 So, after running the vr for the first time since a rebuild its time to iron out a few niggles! Coolant leak sorted, fuel leak sorted now the oil pressure switch on topic the filter housing is leaking!! Ordered two new ones, my question is, why is there two and does it matter which way round they go!!? I've got a yellow lead and a black one/dark blue? Any advice gratefully received!! Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted February 18, 2016 yea it matters .they both do different pressures/things, you know when you switch your ign on but your engine hasn't started your see the oil pressure light flash, this is because of one of the sensors telling you theres no oil pressure, {which is why it goes away when your engine Is started} the other sensor trips an alarm and also flashs if the engine speed/revs are around 2k and pressure drops below a certain amount, Quote Share this post Link to post Share on other sites
Rado87 10 Posted February 18, 2016 Thanks for that. Hopefully it's obvious which one goes where! I'm hoping there's a pressure stamped on them! Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted February 18, 2016 yea the pressure and part numbers are on there, im holding the one that comes on as you switch the ign on in my hand right now as it happens :) , its 0.15- 0.35 bar , 02891901H , the other sender is something like 1.5 bar its higher then this... Quote Share this post Link to post Share on other sites
Rado87 10 Posted February 18, 2016 Spot on. The yellow wire is on the left which I believe is HP. I noticed yesterday that the oil light doesn't come on at all, not even when you put on the ignition! Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted February 18, 2016 your right , here look on the left hand side and scroll down to G2 , then look g2/10 and g2/11 and across to the right has wiring colours, http://www.a2resource.com/electrical/CE2.html Quote Share this post Link to post Share on other sites
Rado87 10 Posted February 18, 2016 Ace bit of info that is mate, spot on! Cheers!:thumbleft: Quote Share this post Link to post Share on other sites
Rado87 10 Posted February 18, 2016 Just out of interest, anyone had there oil light not work at all? New switches hopefully here tomorrow so should cure it. Just wondered what the chances are that the bulb has blown behind the dash? Quote Share this post Link to post Share on other sites
leon263 0 Posted February 18, 2016 Have a read through the post at the link below which I think you will find helpful. I've still got the shortened spanner and the car has gone, so give me a shout if you get stuck. http://the-corrado.net/showthread.php?91334-New-oil-pressure-switches-fitted-VR6&p=1076275#post1076275 Quote Share this post Link to post Share on other sites
Rado87 10 Posted February 19, 2016 Thanks for that mate. Pretty sure I've got an old 24 kicking around I could cut down. I haven't put the slam panel back on yet so hopefully be a simple job. Quote Share this post Link to post Share on other sites
