RS G60 10 Posted March 21, 2016 Hi All, I was trying to get a handle on what I'll be charged to bring together the parts to change my distributor setup to a coil pack. Costs to rebuild the distributor and the difficulty in getting original parts plus the slightly more tidy setup are my motivation. Not interested in going the OBDII option for a few reasons. So the loom, the upper engine cover, the impulse sensor and the camshaft position sensor, coil pack etc. Thanks in advance for any help. Best regards. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted March 21, 2016 I'll have the engine cover maybe a loom and can position sensor Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted March 21, 2016 to confirm I have a loom, cam sensor, side engine plate, plastic engine cover Quote Share this post Link to post Share on other sites
RS G60 10 Posted March 27, 2016 Thanks for the reply lilfuzzer! How much would be after for that lot? Trying to make the whole exercise plug and play if that's possible. Best regards, Ben. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted March 28, 2016 RS G60 said: Thanks for the reply lilfuzzer! How much would be after for that lot? Trying to make the whole exercise plug and play if that's possible. Best regards, Ben. Hi Ben £65 mate cheers chris or I know where there is a brand new dizzy if you would be interested in that Quote Share this post Link to post Share on other sites
RS G60 10 Posted February 6, 2017 Hi All, Just putting this out there again as there didn't seem to be much of a response. Late Coil Pack wiring loom to run with newer style MAF. I have a CH ecu already, if anyone can also clarify if this needs to have an IMO defeat that would be helpful as well. Thank you! Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 6, 2017 So you just need the loom now Ben? Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
RS G60 10 Posted February 6, 2017 Hey Chris, No still need all the parts. I just wanted to be specific about the 1995 aspect as my MAF seems like it has sh*t itself. As you probably know the hot wire MAF is a pain to find at a decent price. I am curious to know why VW used the hot wire MAF for longer in some more expensive models. Golf VR6 Syncro, Corrado, Passat VR6. Also as I may have mentioned I want to utilise a coil pack rather than a distributor. No photos managed to reach me unfortunately. Thanks for any additional help. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 6, 2017 Can you take a picture of your maf and I'll check the wiring I have Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
RS G60 10 Posted February 7, 2017 Hi Chris, I have the 6 (5) pin version at the moment, the is the hot wire version. Required is the 4 pin version that is the same as coil pack Mk3 VR6's. Does that help without having to post a pic? Thanks. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 7, 2017 Yeah pal that's fine. I will take a look what I have mate Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 8, 2017 sorry pal I can only find 6 pin ones Quote Share this post Link to post Share on other sites
