p0l1wrath
Possible ECU fault
Thanks for your help again, never even seen that section of the manual!
That graph seems to line up with my figures, and I can't quite remember, but I'm pretty sure my sensor is reading much higher values then that, so I'll test again tonight!
Yes have checked it for corrosion, it had some greening, thats all cleaned up now.
What about the multiplug in the side of the engine?
Yeh checked that one, thought thats the one you meant first time round for some reason... but yeh, both of those plugs are free from corrosion
