jamesoff 10 Posted May 14, 2016 My MFA seems to be reading too low recently - an average drive where I'd have expected to get around 25-30 MPG, say, is coming out more like 15-20 according to the MFA. Because I use the car infrequently, I haven't been able to verify that this is actually wrong, but given how much out of my last tankful I've used, and the distance since (I zero the trip counter when I fill up), I'm on track for a bit over 300 miles from a tank, which is what I'd normally expect. I've had this before, and the problem was one of the vacuum lines had disconnected from a T-piece. Reattaching it fixed everything, but in this case that doesn't seem to be the problem. I've checked everywhere except the back of the clocks (I hate getting in there, but I wouldn't expect that connection to have failed) and it's all securely attached and in good condition. I replaced quite a bit of it after the previous problem. The car feels like it's running well too. I popped the MFA into the diagnostic mode where you get the vacuum pressure (?) and instant MPG values, and went for a quick drive. I couldn't get the instant MPG over ~20, and even coasting down a gentle incline with my foot off the throttle at 30mph didn't do much over that - certainly not "99.9" which I'd expect at that point. The pressure reading hung around 220, never lower than 190 or higher than 240, but I couldn't see that it was definitely falling or rising under hard acceleration/coasting. I've no idea what range that value is supposed to have, or how it should behave. Anyone have any suggestions for things to try? Quote Share this post Link to post Share on other sites
