quicky1980
Damaged Late Spec Bonnet
I need a late spec bonnet that is no good to anyone as I intend to use only the leading edge. I've got bonnets all around me but are too good to cut up. Anyone got cheap/free late spec bonnet near Warwickshire?
Guest sam1990rhodes
Hi mate have a damaged bonnet, b946pd. Any use for you?
Guest sam1990rhodes
Sorry no, its fairly straight, appears that it blew open in the past and bent the two top corners, started sanding it down to repaint and gave up because of the filler... Wanted a straight bonnet instead. No rush on collection, you can have it for £20 if you want it.
hi mate I know I am quick a distance away but if you ever up here I have a couple spare
you are welcome to one foc
Sorry for not replying sooner. Been very busy.
Sam if you can do it for £10 I'll come collect. I'll be cutting it up so don't want to spend much on it really.
Lilfuzzer, I'll keep you in mind, thanks
