Guest sam1990rhodes
advice on 3 pipes/fuel lines
Guest sam1990rhodes
Hi all,
Got a valver that I'm converting to 20vt, can anyone tell me what thr three pipes (and their colour) by fuel lines... I assume two are fuel lines?, not sure what the third is.
Cheers,
Sam
White or transparent depending on your interpretation is the fuel supply. Blue is the fuel return and black is the fuel vapour breather for the tank.
Guest sam1990rhodes
Thought so, breather for fuel take should go in to a charcoal filter? Can I just leave that disconnected?
In the OEM configuration you are right about the fuel breather. You could leave this pipe disconnected, but the better arrangement would be to return it to the air filter housing, so that the fumes are inducted into the intake air and dealt with appropriately. A simple connection of you choosing will resolve this.
