Daveproyoyoyo 10 Posted May 16, 2016 Hello chaps. Time to play the fun game of guess that worrying noise and this is the first of 2 noises that I have noticed the Corrado VR6 making. This noise I reckon is best described as a clatter/rattle/chirp sort of noise. It seems to be from the passenger side front and is a whole lot worse when going over pot holes and bumps in the road although the chirp part of it can sometimes be heard when stationary and revving the engine but only a little bit. In this video I drove along side a long brick wall in Neutral so the noise is reflected off of that brick wall. I've had a mate say it could be front wishbone rear bush but not really sure. And below is the video for the second noise. This noise is a sort of bang/knocking noise that can be heard only on acceleration. It doesn't have to be hard acceleration. It sounds like its coming from right in front of the drivers seat in the engine bay. It seems to be worst and most noticable when tapping the throttle in first and second gear. Any help would be most appreciated. You can hear the noise better through tinny phone speakers than through good PC ones as the bass gets in the way a lot. Quote Share this post Link to post Share on other sites
Jim 2 Posted May 16, 2016 First one sounds like a loose heatshield possibly? Hard to tell. Second one - sounds fairly hefty! Engine mount? Park the car, open the bonnet, handbrake on as tight as you can (knowing Corrado rear calipers, not always easy!) and put it into first and gradually lift up the clutch into the biting point and see how much the engine is moving? Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted May 16, 2016 Oh I should have mentioned that I just changed front engine mount last week which cured another noise it was making. This banging was there before I changed it and is still there after :-( Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 16, 2016 I'd say check mounts for 2nd noise and I wouldn't drive it either Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted May 16, 2016 (edited) Luckily the rado is a second car so I'll not drive it for a while until these things are fixed, just need to know what it actually is that's going. So I've just popped outside to see if I can get it to make the noise with the car stationary. If I put it in first and gently let the clutch up it doesn't make it but if I give it a few revs and let it up quite fast but only to the biting point it makes the bang. If I have just changed the front engine mount, what else could it be? Edited May 16, 2016 by Daveproyoyoyo Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 16, 2016 Rear engine mount? Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 17, 2016 Rear engine mount? Yep, agree with Chris check the rear mount to rule it out. Quote Share this post Link to post Share on other sites
Jim 2 Posted May 17, 2016 It must be an engine mount given the kinds of noises and how they're occurring. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 17, 2016 Or could it be a drive shaft / cv joint? just thinging. Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted May 17, 2016 Brilliant thanks for the ideas. I'll go and check the rear later this evening. Is there anyway you guys know of to properly check a drive shaft or CV joint should the rear engine mount be okay? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 17, 2016 There's two rear mounts - could be either. How did the car wind up with two duff engine mounts!? Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted May 17, 2016 Absolutely no idea, if anything I'd actually say I'm pretty light footed when it comes to my driving style. I guess just perished over time. I just need to find the time to check them both out or whether its the drive shafts and CV boot like Ray suggested. Hopefully tomorrow evening I'll know what bits to order. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 17, 2016 When i had a CV joint go, i drove round in both directions on full lock listening for knocking and clicking noises Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted May 17, 2016 Okay cool, I'll give that a go and see if it makes the noise worse. Quote Share this post Link to post Share on other sites
