bryn123 10 Posted May 21, 2016 HAVE FOR SALE MY VOLKSWAGEN CORRADO FORMALY A 2.0 16V NOW BEEN CONVERTED TO A 1.8 20V TURBO WONT BORE ANYONE WITH PARAGRAHS GET STARIGHT TO THE DETAILS GOOD POINTS: BODY IS IN EXCELLENT CONDITION SUNROOF WORKS TILT AND SLIDES SPOILER GOES UP AND DOWN AS IT SHOULD TSW WHEELS IN EXCELLENT CONDITION WITH GOOD TYRES INSIDE IS LIKE NEW RUNS AND DRIVES PERFECT FULL STAINLESS EXHAUST WITH DECAT ALL WIRING IN THE ENGINE BAY RE WRAPPED IN CLOTH LOOM TAPE CORRADO HAS 140000 MILES ON IT AGU ENGINE HAD 98958 MILES MOT TILL DECEMBER 2016 ALL GAUGES WORK NEW PARTS: CAMBELT WATER PUMP CLUTCH CLUTCH SLAVE CYLINDER ABS SENSORS X4 MAF LAMBDA SENSOR DIP STICK TUBE SPARK PLUGS OIL OIL FILTER AIR FILTER RAD FAN RAD FAN SWITCH TEMPRATURE SWITCH THERMOSTAT DISCS AND PADS ALL ROUND INTERCOOLER AND PIPE WORK NUMBER PLATES REAR WHEEL BEARINGS BOTH SIDES THROTTLE CABLE FUEL PUMP BOTH HEATER MATRIX IGNITION SWITCH CRANKSHAFT SENSOR CAMSENSOR FRONT WIPER MOTOR FUEL GAUGE SENDER BAD POINTS; BIT OF PAINT BUBBLING BY DRIVERS DOOR HANDLE (IN PIC) WIERD PATCH ON D/S FRONT WING(IN PIC) D/S FOG CRACKED WILL TRY AND SORT BEFORE SOLD D/S RECLINE HANDLE NEEDS REPLACING £3500 ramsgate kent[ATTACH=CONFIG]83863[/ATTACH][ATTACH=CONFIG]83864[/ATTACH] NO TIME WASTERS NO TEST DRIVES WITH OUT PROOF OF INSURANCE Quote Share this post Link to post Share on other sites
