seismicT 10 Posted May 25, 2016 HI there, in need of some technical advice.. read loads of old posts of similar issue to no avail. issue 1: i have Rado 2.0 16v 1994.. the speedo just randomly stopped working i have replaced the speedo sensor on the transmission and have now just replaced the Gauges.. nothing..because the speedo has stopped working in turn the spoiler doesn't activate over 40mph, i have can manually put spoiler up from switch so thats all good... Issue 2: the cars is either shorting or battery dies randomly - today was second time i tried starting the car seemed like battery was dead i tapped the headlight switch to see if it was that and then bam it just about started.. could it be faulty switch?? Issue 3: rattling noise coming from gearbox only in gear 1...looked up could it be shaft bearings?? Issue 4: car revs little high close to 1000 revs.. when im slowing down the car jerks thanks for reading and helping if you can Quote Share this post Link to post Share on other sites
