Bfstrachan 10 Posted June 21, 2016 Need drivers side headlamp - early spec please :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted June 22, 2016 Exhaust manifold, right? Anyway, if i may, can i ask what's wrong with Your headlamp? Broken Glass? Or damaged housing? Cheers-Andrew. Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted June 22, 2016 Broken glass - aye manifold person :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted June 22, 2016 Exhaust manifold, right? Anyway, if i may, can i ask what's wrong with Your headlamp? Broken Glass? Or damaged housing? Cheers-Andrew. You don't happen to have one do you? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted June 23, 2016 I may well have one Left over. IS there any chance you could get the number off the Glass? There should be 3 'E' codes and next to them the actual part number. Does Your Corrado have the early 5 slat grille or later 3 slat Version? Cheers. Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted June 23, 2016 I may well have one Left over. IS there any chance you could get the number off the Glass? There should be 3 'E' codes and next to them the actual part number. Does Your Corrado have the early 5 slat grille or later 3 slat Version? Cheers. Ok, the grille is the early one - it's a 1990 1.8 16v (KR). Hopefully you can make out the numbers from the photos... Thanks for your help again. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
ed1 10 Posted June 28, 2016 Hi, are you still after a headlight?? Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted June 29, 2016 Hi, are you still after a headlight?? Sorry, have managed to one sorted - thanks for the reply! Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
