Fredi 10 Posted July 24, 2016 Been poking around my 2.0 engine bay searching for the culprit of my lurching corrado. I have found a wooden golf tee wedged into air metering head just in front of the large rubber air intake. I guess someone was trying to plug it. What is meant to be there? What should I do with the hole? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted July 24, 2016 It's air/fuel mix adjustment, do not mess with it unless you know what your doing! I speak from experience Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Fredi 10 Posted July 24, 2016 So should there be an air fuel mix screw in there? It is just an empty hole right now. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted July 24, 2016 There's an Allen key adjustment screw down there. It's just a cap to stop water ingress I suppose Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Fredi 10 Posted July 24, 2016 Ah so to adjust the mix one would remove the cap and then insert an Allen key down the hole. I can just plug the hole to prevent any water getting in then? http://vwtech.no-ip.info/images/golf/16vcoscrew.jpg This is the hole I mean. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted July 24, 2016 Yea, loads of info available just search for kr fuel mix screw Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Fredi 10 Posted July 24, 2016 Many thanks swift kid Quote Share this post Link to post Share on other sites
