Beaver2low 10 Posted August 17, 2016 My buddy has a 91 g60. Its not passing 5000rpm before it cuts out. I have drivin it and there is barely any pull. I have a mk4 jetta 2.0 with better pull then it. Any help would be nice. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 17, 2016 Could be loads of things mate. Fuel pressure that's low, blocked fuel filter, hall sender inside dist. playing up, timing belt skipped a tooth, worn plugs, choked up air filter, low compression 'cos of worn rings, knackered G-charger not putting out much boost, the list goes on.. Try the simple stuff first though, change the fuel filter and service the car,new engine oil, plugs etc. Quote Share this post Link to post Share on other sites
