Feathers 10 Posted October 11, 2016 Looking to buy back my old car 16v dark blue reg L345UGE anyone got knowledge of its whereabouts? Quote Share this post Link to post Share on other sites
Jim 2 Posted October 11, 2016 Showing as having a current MOT and is insured - so at least it's still on the road. Hope you find it! :) Quote Share this post Link to post Share on other sites
Feathers 10 Posted October 11, 2016 Thanks Jim obviously someone cares!!!! Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 11, 2016 Check the MOT history of a vehicle Registration number: L345UGE Vehicle make: VOLKSWAGEN Vehicle model: CORRADO Date first used: 31 December 1993 Fuel type: Petrol Colour: Blue MOT history of this vehicle Test date: 23 July 2016 Expiry date: 24 July 2017 Test Result: Pass Odometer reading: 121,143 miles MOT test number: 6000 1868 8551 Advisory notice item(s): nearside rear upper Vehicle structure has slight corrosion strut top (6.1.B.2) has had extensive welding to floor pans heavly undersealed front Oil leak () front Bumper insecure support rotton () Test date: 22 July 2016 Test Result: Fail Odometer reading: 121,137 miles MOT test number: 7215 4708 7319 Reason(s) for failure: offside rear Brake hose ferrule excessively corroded (3.6.B.4e) offside rear lower Subframe mounting prescribed area is excessively corroded chassi leg (2.4.A.3) offside front lower Suspension arm has excessive play in a ball joint (2.4.G.2) Advisory notice item(s): nearside rear upper Vehicle structure has slight corrosion strut top (6.1.B.2) has had extensive welding to floor pans heavly undersealed front Oil leak () front Bumper insecure support rotton () centre front Gearbox mounting defective () Test date: 22 July 2015 Expiry date: 24 July 2016 Test Result: Pass Odometer reading: 118,804 miles MOT test number: 6687 8370 5215 Advisory notice item(s): Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c) Offside Rear Brake hose has slight corrosion to ferrules (3.6.B.4e) Oil leak Test date: 15 July 2015 Test Result: Fail Odometer reading: 118,804 miles MOT test number: 1061 4659 5186 Reason(s) for failure: Offside Front Headlamp not working on dipped beam (1.7.5a) Exhaust emissions carbon monoxide content at idle excessive (7.3.D.4) Advisory notice item(s): Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c) Offside Rear Brake hose has slight corrosion to ferrules (3.6.B.4e) Oil leak Test date: 25 July 2014 Expiry date: 24 July 2015 Test Result: Pass Odometer reading: 114,140 miles MOT test number: 4883 9620 4222 Advisory notice item(s): Offside Body has slight corrosion (6.1.B.2) Test date: 25 July 2014 Test Result: Fail Odometer reading: 114,140 miles MOT test number: 7650 8630 4298 Reason(s) for failure: Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2) Offside Headlamp not working on main beam (1.7.5a) Advisory notice item(s): Offside Body has slight corrosion (6.1.B.2) Test date: 19 July 2013 Expiry date: 24 July 2014 Test Result: Pass Odometer reading: 109,297 miles MOT test number: 3975 3080 3299 Advisory notice item(s): Offside Front Track rod end ball joint has slight play (2.2.B.1f) Offside Rear Shock absorber has a light misting of oil (2.7.3) Test date: 25 July 2012 Expiry date: 24 July 2013 Test Result: Pass Odometer reading: 104,785 miles MOT test number: 2173 6740 2246 Advisory notice item(s): Front Brake pipe slightly corroded (3.6.B.2c) Nearside Rear Brake pipe slightly corroded (3.6.B.2c) Offside Rear Shock absorber has a light misting of oil (2.7.3) Test date: 8 October 2009 Expiry date: 1 November 2010 Test Result: Pass Odometer reading: 102,098 miles MOT test number: 2127 7168 9296 Test date: 6 October 2009 Test Result: Fail Odometer reading: 102,097 miles MOT test number: 3640 1997 9435 Reason(s) for failure: Centre Brake pipe excessively corroded (3.6.B.2c) Nearside Rear Brake pipe excessively corroded (3.6.B.2c) Nearside Rear Brake hose ferrule excessively corroded (3.6.B.4e) Nearside Front Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.2) Offside Front Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.2) Offside rear parking brake recording little or no effort (3.7.B.6a) Emissions not tested (7.0) Parking brake: efficiency below requirements (3.7.B.7) Advisory notice item(s): Offside Rear brake disc slightly pitted (3.5.1h) Test date: 7 October 2008 Expiry date: 1 November 2009 Test Result: Pass Odometer reading: 98,580 miles MOT test number: 8500 2168 8251 Test date: 6 October 2008 Test Result: Fail Odometer reading: 98,579 miles MOT test number: 4332 9088 8261 Reason(s) for failure: Offside Stop lamp not working (1.2.1b) Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1) Test date: 2 November 2007 Expiry date: 1 November 2008 Test Result: Pass Odometer reading: 94,910 miles MOT test number: 1317 8670 7387 Test date: 24 November 2006 Expiry date: 8 December 2007 Test Result: Pass Odometer reading: 91,040 miles MOT test number: 2234 0822 6322 Test date: 9 December 2005 Expiry date: 8 December 2006 Test Result: Pass Odometer reading: 86,922 miles MOT test number: 7435 3354 5333 Test date: 8 December 2005 Test Result: Fail Odometer reading: 86,922 miles MOT test number: 3403 0214 5301 Reason(s) for failure: Nearside Rear Fluid suspension unit leaking (2.4.D.2) Offside Front Lower Ball joint has excessive play (2.2.B.1f) Nearside Rear rear parking brake recording little or no effort (3.7.B.6a) Parking brake: efficiency below requirements (3.7.B.7) Quote Share this post Link to post Share on other sites
Feathers 10 Posted October 11, 2016 Thanks for the MOT info. For your info car was in my possession from jan 1996 until sept 2010 Quote Share this post Link to post Share on other sites
Feathers 10 Posted October 11, 2016 Could be in the market. How much would you be asking? Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 11, 2016 Could be in the market. How much would you be asking? You best pm me if your asking about mine. Quote Share this post Link to post Share on other sites
