reggiebaby
Front cross member
Hi can anyone tell me what the panel is called that is on the bottom of the front cross member/rad support, or is it all one panel.
Thanks
the radiator carrier is seperate from the the engine cradle
Ok thanks, so to get it out will need to support the engine and remove the mount. It needs to be gone more rust than metal.
Just support the feont of he engine and release the mount nut then the big 17 on either side to get out as one unit the you can separate them by removing the smaller bolts. Remember to soak the bolts prior to removal to ensure none break
Sent from my SM-G357FZ using Tapatalk
Anyone know the part numbers or where I can get replacement bolts for the radiator carrier and engine cradle 2 small and one large each side. Thanks all.
