robrado974 1 Posted March 29, 2017 Evening chaps . I've now put my underside back together . One wheel was perfectly upright and true , the other was miles out. Am I right in thinking the camber is adjusted by the two nuts and bolts on the suspension where the hub bolts to ?. Kind regards Rob Quote Share this post Link to post Share on other sites
Rado87 10 Posted March 29, 2017 Yea that's right mate. I've recently done mine. From memory I think you just loosen them off and pull the top of the wheel right out and that's where it needs to be. I used my iphones angle finder believe it or not to achieve a negative 1 camber!! Worked a treat! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 29, 2017 Great stuff thank you . Quote Share this post Link to post Share on other sites
