robrado974 1 Posted March 30, 2017 I seem to have Miss placed my washers , the ones for the 17 mm bolts, that hold the hub to the suspension leg . Are these special?. I don't remember these coming off the car . Thanks Rob Quote Share this post Link to post Share on other sites
Rado87 10 Posted March 30, 2017 Can't remember mine having washers. The bolt heads were 19mm though not 17? I wonder if at some point a thinner bolt was used on yours to allow for more adjustment for the camber?? If so, pulling the top of the wheel right out to the stop might not be correct. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 31, 2017 Thanks chap . I cleaned the mess up yesterday as I finished work early. The bolts are 18mm, my mistake. I adjusted it so the wheel is now upright, but it will have to go in for proper alignment. I also ordered the JnR boot . Quote Share this post Link to post Share on other sites
