Peter DH 10 Posted May 12, 2017 My 1990 16v corrado has stood for sometime unused when switching on the ignition, i cannot hear the fuel pump run. The fuse is ok but there is no power at the pump feed wires. Is there a hidden fuse or even a relay i can check out? The car has an immobiliser which is activated by a little fob inserted into a slot beside the gearstick does this sound like standard equipment or an aftermarket fit? If this is faulty would it make the pump immobile? Thankyou for any help! Quote Share this post Link to post Share on other sites
