harrisvr6
VR6 Rear brake to hub bolts.
Does anyone know where to source the bolts that hold the rear brakes on (the hex ones that are notorious for stripping), I belive there is 3x?
TPS is saying it's a discontinued item and, I am in dire need of some new ones so I can finally put an end to my rear brake bearing issue... Does anyone know if they are available at all at all parts or G&S?
In the manual it says they are high tensile steel, if I cant find them would another bolt of the same thread suffice (maybe normal steel at a push)?
