20ValveT
Electrical issues
Hi all,
Hoping for some advice on electrics as I'm not the best with it!
I was driving home in my corrado which I recently bought from a member on here.
While driving I lost the the blowers, instrument cluster inc speedo, tachometer, temp, fuel (the digital clock is working), & the total mileage shows, but does not change. The trip computer does not operate either.
The sunroof also lost its retract function however it still tilts.
I checked the fuses and the blower fuse has blown however I don't know why all of this happened Nd I'm worried there is an underlying fault somewhere.
It was red hot and I had the fans in full as well as the stereo and so on. Could that have something to do with this?
I'm sure that the blower fuse in is only a 10 amp fuse however I've seen a diagram showing it should be a 20 amp fuse?
Can anyone shed any light on these issues?
Cheers,
Mark.
I am new to corrado myself so can't help you a lot but l say the fan fuse is a 20 amp as it pulls a lot of currant.,
Check the leads to the battery,Sorry l can not be more help
