1200 bandit 10 Posted July 12, 2017 Have got a interment runing fault on my 1993 2.0 16 value.also have a oil leak around the dizzy. Had a look on eBay found a new dizzy for £44.95 all in Hopefully this will cure the runing fault, as the scanner l got will not communicate with the Corrado :dance: Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted July 14, 2017 New dizzy fitted no more oil leaks,hopefully no more none starts, hard starts,cutting out Set the timing to 6 BTDC is correct Quote Share this post Link to post Share on other sites
