1200 bandit 10 Posted July 17, 2017 I have just scanned the corrado 1993 2.0 16 value with a sanp on scanner Have got a permanent fault 00516 CLOSED THROTTLE (IDLE)POSITION SWITCH (F60)OPEN CIRCUIT/SHORT WITH POWER This is the code l got of the sanp on scanner,Is it the the 2 micro switches that are on the throttle body or something else,l have removed the micro switchs ,have 12 volt reading on the gray wiring uesing the centre wire as the earth,also got a reading from the rear switch on the throttle body but no reading from the front micro switch. if anyone knows,has a switch/sensor ect for sale,can please let me know :scratch: Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted July 21, 2017 Been playing with the corrado,When start the engine is was like a engine misfire.so got a new dizzy not the fault.I did borrow a scanner after l got the dizzy.see above.Before l removed the switches l found that the front micro was not clicking when throttle was moved. Removed the switchs and checked.refitted the switchs adjusted the front switch so when moved throttle the switch now clicks. The engine now starts and runs spot on.will have to borrow the scanner again to check it out If abody needs a good working dizzy l have one. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted July 25, 2017 OK Have rescanned the corrado sill have the above fault.Is it the micro switchs on thr throttle body or l pi##ing in the wind Anboby any information Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted July 25, 2017 Hi, Did you erase the code the first time around? One switch is the closed throttle and the other is for wide open throttle. If the switch wasn't clicking before but is now and all is well then I'd say that's problem solved. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted July 26, 2017 Have adjusted the switch now clicks wh en throttle moves the fault is permanently there The car now runs, starts ok (after finding the wiring to the engine temperature switch had fell off in side the wiring block)the car pulls like a train Can't get rid off this fault. Quote Share this post Link to post Share on other sites
