Woodsy_is_back 0 Posted August 1, 2017 Hi guys Got a real issue with my PAS I fill it up, run the car with no issues with steering, park or with the reservoir still full and when I return its leaked all the fluid I can't spot the exact source of the leak, somewhere round the back of the gearbox/steering rack The drip is coming off the subframe I'm struggling for why it would be leaking when not under pressure rather than when pressurised 🤔 Any help gratefully received Woodsy Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 1, 2017 Jack up the front of the car, start it and let it run for a bit then get underneath and clean the effected area best you can then crawl underneath (jackstands a must before venturing under..) get someone to turn off the engine and start looking. Sounds like a buggered rack seal, could be a loose pipe union. Difficult to make a diagnosis over the net, especially in your case where the leak only leaks when the engine is stopped, this is a first.. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted August 1, 2017 It may be leaking into the steering rack boot (internal seal leaking)than slowly leaking out though the boot Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted August 1, 2017 Really appreciate the help with that, thanks guys Had a feeling it's the rack seals, I saw a thread about replacing the seals, bit out of my abilities so looking for a replacement rack I guess 👍 Quote Share this post Link to post Share on other sites
